Old 02-23-2018, 07:31 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Education, Chevrolet LS engine mechanical roller valve train
Racers,
Help me begin my education of the LS engines mechanical roller valve train.
Questions:
*considering the LS3/L92 rectangular-port head.What is required for valve springs and rockers to accommodate adjustable rockers and .750" range lift?
*This engine will spin in the 7800 RPM range and make around 700 horse. It will be carburated with a powerglide, dedicated, trailered, serious drag race package.
I am not interested in a non-adjustable, hydraulic valve train.
Larry Woodfin 471W
Old 02-24-2018, 03:30 AM   #2
Dragsinger
Default Re: Education, Chevrolet LS engine mechanical roller valve t
For future reference, the LS series has many options and all the parts and modifications we are accustomed to with the generation 1 SBC are also available for the LS series. Mechanical, link bar roller lifters, adjustable & shaft rockers, valve springs to accommodate.750" lift. Also, Brodix, Dart, and GM offer a number of race head packages.
Larry Woodfin 471W
Old 02-25-2018, 11:16 AM   #3
rx dealer
Liked 53 Times in 13 Posts
The block must have the lifter bores bushed to help control the oil flow to the top of the valve train. If you don't you will flood the top end of the engine. The valve springs are critical. I went from having a "recommended" valve spring #860 open to a weaker valve spring that is #90 less. The heavy spring was making the valve to bounce after closing. I spent the extra money to put these parts on a spintron and that was my proof. Rocker shaft is a must ( Jesel / T&D ). Luke
rx dealer is offline   Reply With Quote
Old 02-25-2018, 09:44 PM   #4
L79racer
L79racer's Avatar
Im running a LS3 based 418. Stock block and sleeves. Trick flow genx 255 heads by TEA. low lash solid roller by cam motion. morel lifters, jesel shaft rockers. pac 1238X springs, manton push rods. I have not bushed the lifter bores. Running a glide with it. Shifting 8000. Making over 700 hp.
L79racer is offline   Reply With Quote
Old 02-25-2018, 09:49 PM   #5
Dragsinger
L79, you are in the area of what I have in mind. Thanks for the note
Larry Woodfin 471W
Old 02-26-2018, 02:59 PM   #6
JRyan
Liked 112 Times in 31 Posts
That's a pretty good street/strip set up that L79 racer is using. Should be very low maintenance a shouldn't break the budget. The LS platform is such a great platform to work with. Decent springs, good lifters and a nice cam profile they'll turn 7500 with stock rotating assembly's.
Rick
