Old 09-26-2017, 07:53 AM   #1
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
Default Mopar Parts Identification Help Needed
I have a group of Timken bearings in Mopar boxes that I believe are for a Dana 60. If anyone has access to checking these numbers, I would like to confirm fitment. Not having much luck with Google. The packages are from 2000. The first number is the Mopar number and the second number is whats on the bearing. Thanks for any help.
01790541 LM603049
03723569 LM603012
02800485 M802011
02800484 M802048
02070316 M86649
02070317 M86610
52067595
Joe Marcinowski 3377 STK
Joe Marcinowski is online now   Reply With Quote
Old 09-26-2017, 08:25 AM   #2
bert powell
Liked 34 Times in 12 Posts
Default Re: Mopar Parts Identification Help Needed
Here is what I have written down:
• Timken Inner Pinion Bearing P/N HM803146-HM803110
• Timken Outer Pinion Bearing P/N HM88542-HM88510
• Timken Carrier Bearings 2 EA P/N 387A-382S
bert powell is offline   Reply With Quote
Old 09-26-2017, 08:53 AM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Joe -
You can use the Timkin numbers and do a search at www.Rockauto.com. It will show what vehicle the parts will fit over multiple brands.
For example - the LM603049 fits 1957-64 Full-size Chevrolet and some late model Fords.
The last number is a pinion seal -
CHRYSLERPROWLER2001-2002DODGEDAKOTA1997-1999DODGERAM 2500 PICKUP1997-2003JEEPCHEROKEE2000-2001PLYMOUTHPROWLER1997-2000
Good hunting!
Lew Silverman #2070
"The Wagon Master" N/SA
Last edited by Lew Silverman; 09-26-2017 at 08:59 AM. Reason: New information! :-)
Old 09-27-2017, 01:57 PM   #4
Joe Marcinowski
Thanks guys.
Anyone else that can check the Mopar numbers?
Old 09-28-2017, 01:27 AM   #5
Lew Silverman
All these numbers came up in a Google search, and none of them look to be bearings for a Dana 60 Axle -
https://www.google.com/search?q=0179...utf-8&oe=utf-8
https://www.google.com/search?q=0372...utf-8&oe=utf-8
https://www.google.com/search?q=0280...utf-8&oe=utf-8
https://www.google.com/search?q=0207...utf-8&oe=utf-8
https://www.tascaparts.com/oem-parts...SAAEgIP__D_BwE
They all look to fit later model Dodge and Jeep products.
Lew Silverman #2070
Old 09-29-2017, 05:47 PM   #6
Joe Marcinowski
Thanks Lew. Cleaning the garage and came across these. Cant for the life of me figure out how I ended up with them. Only Mopar rear end I ever owned was a Dana 60.
