Old 09-07-2017, 02:11 PM   #1
Makinchips
Default Chevelle front suspension questions
I'd like to raise the front ride height of my Chevelle.
How can I do this without using new springs and trimming them?
Makinchips is offline   Reply With Quote
Old 09-07-2017, 03:23 PM   #2
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: Chevelle front suspension questions
Mr. Gasket #1285, hard rubber spacer installs above or below spring. That will raise it about an 1". Allstar Performance makes thin steel spacers if you want to raise it just a small amount, 3/16" or 1/8", Allstar #56120 or #56121.
Jim Kaekel 3836 STK
Old 09-07-2017, 04:58 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
There are also some rubber spacers that you stick between the coils . They don't require you to disassemble anything , just stick them in .
Old 09-08-2017, 10:24 AM   #4
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
They make spacers you install when car is up on jacks and suspension hanging. Both screw in and bolt in.
Mr gasket had them many moons ago.
They go right between exposed coils
Google mr gasket spring spacer. Many styles appear.
chris ok is offline   Reply With Quote
