Old 08-07-2017, 09:41 AM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default more thoughts about needle bearings
Consider this thought,
In ref to bushed lifters vs needle bearing lifters, driveshafts have needle bearings in the u-joints.
Larry Woodfin 471W
Old 08-07-2017, 10:55 AM   #2
carl hinkson
Liked 18 Times in 10 Posts
Default Re: more thoughts about needle bearings
I am not sold on bushing lifters yet, That being said I have supplied some customers with .937 Morel roller lifters that have worked fine.
Most of my builds I have been using the Morel .904 lifters with needles in about everything and to date not one problem.
carl hinkson is offline   Reply With Quote
Old 08-07-2017, 01:46 PM   #3
Hacksaw
Liked 311 Times in 175 Posts
Guys like Carl and other engine builders would obviously see the results and the pros and cons of each type. I am no expert, IMO the needle type is more efficient than a bushed lifter. What causes a roller on a needle bearing lifter to stop turning and goon the cam etc. ? I think if the engine gets a flash of rpm, like wacking the throttle in the water, the spring slams the lifter on the cam and it puts a flat spot on a needle and that leads to a failure.
Old 08-07-2017, 03:19 PM   #4
Ed Wright
Ed Wright's Avatar
I have run needle bearings (Isky Red Zone) for a few years now, with zero problems, as long as I send them back for a "rebuild" every winter. They won't go two seasons. Mine seldom sees over 8300, with 1015 lbs Open spring pressure.
Your results may vary. LOL
Ed Wright 4156 SS/JA
Old 08-07-2017, 03:25 PM   #5
carl hinkson
I have had more problems with ISKY roller lifters only as far as sizing, Never been able to buy just one set always 2 sets and one build took 3 sets to get the sizing correct.
Old 08-07-2017, 05:00 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,939 Times in 583 Posts
What valve springs are you using?
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 08-07-2017, 07:10 PM   #7
Ed Wright
Ed Wright's Avatar
I have not had that problem.
Old 08-07-2017, 07:14 PM   #8
Ed Wright
Ed Wright's Avatar
Originally Posted by mike pearson View Post
what valve springs are you using?
1356 pac.
Why does it keep changing caps to lower case??
Old 08-07-2017, 08:25 PM   #9
Mike Pearson
1356 pac.
Thanks Ed
Old 08-08-2017, 09:23 AM   #10
Ed Wright
Ed Wright's Avatar
Thanks Ed
1.5" diameter. I can get on all my head bolts.
