Old 08-03-2017, 12:52 PM   #1
Jeff Stout
Liked 704 Times in 281 Posts
Default Adding weight to a 4 link G body?
I built this car like my old Super Stock Monte aftermarket 4 link with the exception of mini tube and using 12x30 tire. My question is I need to add weight and I know on top of the rear end is a great place, but wanting to know adding weight on frame where 4 link would intersect would be a great place. I'm looking to add 150lb at floor behind drivers seating and my thought was 4 link would work rear tires harder and plant them better knowing it had the weight at the intersection of 4 link. Any thoughts? Thanks in advance. Jeff
Old 08-03-2017, 04:12 PM   #2
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: Adding weight to a 4 link G body?
Rear seat belt hold downs.
Jim Kaekel 3836 STK
Old 08-03-2017, 04:53 PM   #3
Jeff Stout
Thanks Jim. I had someone private message me the same location but try to go higher such as rear roll cage down bars. Now to come up with 150lb and secure as I only have 60lb of lead.
Old 08-03-2017, 05:53 PM   #4
Rsmith38
Liked 28 Times in 15 Posts
If you mount a weight box (Moroso - Competition eng) to the hold downs (or a flat steel plate) you can add pieces of steel, wrenches, etc to the box - in addition to the lead.
Rsmith38 is offline   Reply With Quote
Old 08-03-2017, 06:21 PM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Keep weight below the top of the wheelwells (per the rules) Weight ahead of the rear axle will add some static weight to the front end , but could add some dynamic weight during the launch .
ss3011 is online now   Reply With Quote
Old 08-03-2017, 07:02 PM   #6
Jeff Stout
Thanks for reminding me about height at wheel wells per rules.
Old 08-04-2017, 11:12 AM   #7
Rusty Davenport
Liked 101 Times in 27 Posts
Can the weight box be secured by a thick "sandwich" plate under the car or does it have to be welded to a structural member of the car ????
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 08-04-2017, 01:27 PM   #8
Rsmith38
Mine is bolted thru the pickup bed - Been thru tech at Nationals and Divisionals for years - don't know if it is in the rule book - 6 bolts on the Moroso box.
Old 08-04-2017, 05:25 PM   #9
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
Unless you are going through a frame crossmember, that does not appear to be legal.
Per Section 11a, page 6 of the 2016 Super Stock Rules:
BALLAST.
Weight box permitted. Only 100 pounds removable ballast permitted, including box (two-box maximum with 50 pounds each). Must be attached to frame or crossmember with minimum of two 1/2-inch bolts. May not be attached to roll bar or cage. Additional ballast must be permanently attached to frame or crossmember; i.e., bolted with at least two 1/2-inch bolts per 100 pounds, with nut welded to bolt. See WEIGHT. See General Regulations 4:2.
I have seen cars and talked with racers who have been through tech at numerous National and Divisional events with weight boxes NOT attached to a frame member. They all told me it was never a problem. So I mounted mine in the corner of the trunk floor with a large plate on the bottom and six bolts holding it in place. Second or third divisional I attended I was told to read the rule book and change it before the next race.
Larry Merk
Larry Merk is offline   Reply With Quote
Old 08-04-2017, 05:42 PM   #10
Jeff Stout
BALLAST.
I'm guilty of not having the latest rule book and now knowing that you can't bolt weight to roll bar. I know of one car that has it that way. Mmmmm
