Liked 2 Times in 2 Posts
How much horse power can be made with a 459 intake? On a 327 stroker, possibly a 383. Acid ported and hand ported. What kind of power levels do the 327 300 make with a 459 and AFB in stocker form? Any if would be helpful. Thanks.
Scott Chalk 1226 I/SA |
350 lookers, but no comments? Or info???
Liked 7,933 Times in 1,518 Posts
Not as much as an out of the box Edelbrock alum intake manifold.....
Obviously, im gonna build an engine for a Factory stock style class. Similar to the FAST series. Has to have factory carb and intake. But you can port heads, increase cubic inches, different cam ,etc. Just wondering what the limits of the 459 intake are?
Liked 5,120 Times in 1,951 Posts
Scott, Probably not hearing anything because nobody here has first hand knowledge .
There might be one or two 300 hp Stockers out there , but that doesn't help you much with a 383. All I know is it's worth a bunch over a real 283 intake. Does the carb have to be stone stock, or NHRA Stock?
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 07-26-2017 at 11:52 PM. |
Obviously, I didn't realize you were building an engine for a factory stock style class....sorry......
Liked 28 Times in 11 Posts
Acid ported and hand ported in stock ????? Now who would incriminate themselves by admitting this?
EX 5-Doorstocker |
Liked 454 Times in 147 Posts
I would guess an average 350 stocker engine with a 750 Q-jet with that manifold you asked about is in the 415-425 HP range. A really good motor is in the 430-440. The 459 as all the stock SBC manifolds due, fall off in the higher RPM ranges. Important the cam works with the manifold. (Acid dipped or not.)
This is not for a stocker. I was saying that the class I'm gonna run that the intake can be modified.
#10 | |
