Old 07-13-2017, 08:27 AM   #1
nhramnl
Liked 358 Times in 83 Posts
Default Slick Usage Question
Wondering how many Super Stock racers use bias-ply tires for most of their runs, but put on radials when they have to go as quick as possible (e.g. heads-up race during eliminations, running for class, etc.). Also, for those who do use bias-ply tires, what is your usual air pressure? Thanks very much.
Old 07-13-2017, 09:03 AM   #2
Marc LaBrecque
Liked 432 Times in 115 Posts
Smile Re: Slick Usage Question
We've had awesome luck with M/T tires both radial and bias ! Your spot on with bias on a every day use our truck is a GT/TC truck 327-250 short time in the 1.31-1.33 range . We run 18lbs in the radial and with the 14/32 bias 14 - 15 depending. We change the bias out because we feel guilty not performance based around 150 passes. The Mickey's have been awesome ! Hope this helps.
Marc
Old 07-13-2017, 10:52 AM   #3
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Slick Usage Question
IMO, radials are the baddest tires out there if you can make your car work with them.
I'm just a lowly bracket and Super Street racer, but I put 240 passes on my last set of 9" Hoosier radials.
S/ST 51
S/C 53
Old 07-13-2017, 05:26 PM   #4
Coleydog
Liked 53 Times in 38 Posts
Marc
Do you change the fronts also, bias-bias and radial-radial?
Old 07-14-2017, 06:46 PM   #5
Hacksaw
Liked 314 Times in 177 Posts
Nobody changes fronts. Never seen a drag specific front tire offered in a radial.
Old 07-14-2017, 07:30 PM   #6
Coleydog
Thanks, good to know, now I won't waste my time looking for one.
Mike
