Old 05-11-2017, 02:31 PM   #1
SDT1DYI
Liked 456 Times in 148 Posts
Default 68-70 Nova Stocker Pinion Angle
SB 350 Stocker 12 Bolt. TH 200 Transmission, with Caltrac bars and Mono Leaf springs. What would be the proper Pinion angle to start with
Thks for the Help.
SDT1DYI is offline   Reply With Quote
Old 05-11-2017, 03:01 PM   #2
Painter
Liked 162 Times in 45 Posts
Default Re: 68-70 Nova Stocker Pinion Angle
Some is good, a little more is better. More is better. If you have trouble hooking the driveshaft it, it mite be too much. Dont be bashfull!
Painter is offline   Reply With Quote
Old 05-11-2017, 03:32 PM   #3
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: 68-70 Nova Stocker Pinion Angle
I run 3 degrees down on ours.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 05-11-2017, 07:13 PM   #4
Joe DeMarzo
Liked 123 Times in 11 Posts
Talking Re: 68-70 Nova Stocker Pinion Angle
6 degrees here in NY
Joe DeMarzo 1317 STK
Old 05-11-2017, 07:35 PM   #5
SDT1DYI
Its at .06 now. Was going to install 2 degree wedges to start but maybe I should install the 4 degrees and see if it likes it to start. Anybody play with a pyrometer readings at the U joints?, checking temps with Pinion angle changes to determine best angle. Thinking is, closer the angle is under a load, the less heat is being generated by the U joint as it rotates.
Old 05-11-2017, 08:12 PM   #6
GTX JOHN
Just a couple or three degrees in Boulder City works great.
John Irving
741 Stock
741 Super Stock
Old 05-11-2017, 09:21 PM   #7
Todd Bailey
Liked 33 Times in 17 Posts
Call Travis at Calvert racing.
Todd Bailey is offline   Reply With Quote
