Liked 118 Times in 41 Posts
On my 79 Mustang stocker I want to leave the back seat in. My Roll bar will go thru the speaker holes. my question is, do I still have to put in a aluminum rear firewall behind the seat, due to the fuel cell in the trunk, or will it be ok without it?
U/SA 79 Mustang |
Liked 70 Times in 29 Posts
I would say the answer is yes because the seat doesn't close the area off clear to the glass. I would do it anyway for my own safety even if it wasn't required by rule.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 2,953 Times in 710 Posts
According to the 2017 rule book if a fuel cell is used you must remove the stock tank. The panel between the trunk and the interior must be covered with either .032 aluminum or .024 steel. Hope this helps you.
Ron McDowell - Did Race Every day is a Gift - Enjoy with family and friends. |
Thats the way I read it too but it never hurts to ask people who know for sure.
U/SA 79 Mustang |
Liked 275 Times in 76 Posts
With a hatch you will need to seal off the hatch to separate the trunk area from the driver's compartment no matter what you do. If it's a notchback, then you will still need to add the firewall. I have had tech people inspect how I sealed the hatch more than anything else on my car at multiple divisions. Since you have a notch back, you will need to cover the backseat and possibly the deck plate where the speakers/rollbar is. Make it seal good and no gaps otherwise it could be questioned.
Sean
What is the best thing to use to seal it with?
U/SA 79 Mustang |
Liked 53 Times in 38 Posts
Not to highjack this thread but a similar question, what if the cell is mounted under the trunk floor with a hinged hatch above the fuel door?
Liked 12 Times in 6 Posts
A change in the rules that I would like to see. If you use a fuel cell and put a fire wall in but don't need a roll bar because of class you shouldn't need to put your rear seat back in.
If you make it fit tight that should be sufficient. Take it one step further and buy some really thin and light carpet from autozone or O'Reilly and glue it on your firewall. Then it looks neat and finished and won't blind you if the sun hits it when fueling the car.
Liked 346 Times in 126 Posts
