I have a -93 Lt1 intakemanifold and a -97 intake, witch intake should I use on my stock b/sa Camaro?
Liked 2,336 Times in 549 Posts
Liked 184 Times in 113 Posts
Lt1 -93 intake casting nb 10208145 has no crossover pipe between fuilrails behind map so it has straight inner roof.
Rectangular ports with injectors located straight pointing to head intakerunner Lt1 -94-97 intake has a crossover pipe between fuilrails behind map and create a small bumb on the inner roof just after Tb. Ports match more or less to the head and sized as the head intake runners+injectors are angeld against intake valve. You can see a few -93 intake on 93-98 f-body so i just wonder if missed something. |
Actually there are three different LT1 intakes.
The 1992-93 intake (10208145) has no fuel crossover and rectangular ports. If you run this I would modify some of the later fuel rails. The 1994-1996 (10106830) intake has a fuel crossover and rectangular ports. The 1997 (12552138) has a fuel crossover and ports that almost match the head. Some comparison photos. The red intake is an LT4. ![]() ![]() |
The 12552138 intake is the way to go if you locking on port shape and the injector angeld against intake valve.
I have the 630 intake on my camaro so i might change. You can find the 138 intake on the -96 f-bodys as well. |
Ok i get it.
