Old 03-30-2017, 05:46 PM   #1
jmoneyfoot
Liked 9 Times in 5 Posts
Default How many passes to a set of tires?
How many passes can a guy put on a set of tires before 60fts state going away? Thanks Jake from MN
jmoneyfoot is offline   Reply With Quote
Old 03-30-2017, 06:03 PM   #2
Rod Greene
Liked 242 Times in 81 Posts
Default Re: How many passes to a set of tires?
That is a loaded question. Auto, Stick, Bias, Radial, how long of a burn out, engine combo are all factors that have a bearing on tire life. The best indicator is your time slip.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is online now   Reply With Quote
Old 03-30-2017, 06:41 PM   #3
jmoneyfoot
Powerglide, bias ply, 3300lb car 450hp short burnout.
Old 03-30-2017, 11:30 PM   #4
Everett Vassar
Liked 2 Times in 2 Posts
Fairly heavy car,not a lot of HP,bias ply slicks, I would run those suckers till you start seeing cords...or they start spinning
Everett Vassar is offline   Reply With Quote
Old 03-31-2017, 09:58 AM   #5
cmracing
Liked 62 Times in 29 Posts
I used to get 250+ passes (1/4 mile) going 10.00 with 29x10.5's Hoosiers @ 18 - 20psi, would still work with cords showing, that is when they got tossed! 3300lbs 1.80 Powerglide 4.30 gears at the time, 5500 rpm convertor. Put a lot of nitrous passes on them too going 8.8 @ 155+..........
cmracing is offline   Reply With Quote
