Old 02-17-2017, 11:59 AM   #1
pfordamx
Liked 7 Times in 5 Posts
Default 1970 AMX hood scoop
ok this is for the 2 or 3 guys that have ran a 1970 AMX, i've heard the hood-scoop is too low and really not effective, my question is should i just use as big a air cleaner as i can fit under the hood and treat it like there is no scoop, or should i go ahead and try to seal the carb to the scoop. i'm kinda hoping someone has tested this and is willing to share there experience.
Thank you
Patrick Ford
pfordamx is offline   Reply With Quote
Old 02-19-2017, 01:49 PM   #2
jmantle
Liked 172 Times in 81 Posts
Default Re: 1970 AMX hood scoop
Thank you
Patrick Ford
I have no experience with the 70 AMX hood but on my partners Hornet we ran the SC360 scoop sealed up to the carb and it worked ok. It definitely was not slower with the carb sealed up and the scoop opening on the AMX looks to be about the same size. This was on a low 10 second bracket car.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 02-21-2017, 09:51 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Having owned and raced several 70's ,I can tell you it does have some benefit.
Anytime you can have outside air over engine compartment temp ,you take it .
use the air cleaner base only , without the seal
Old 02-21-2017, 01:08 PM   #4
pfordamx
Thanks Tom i was hoping you or Jeff Lee would chime in, that is what i will do.
Old 02-27-2017, 03:16 AM   #5
amxron
Never did an a-b but, the buttometer says sealed. Boundary air is cooler
than underhood air.
The AMX scoop is higher than the S/C360 scoop.
Ron.
amxron is offline   Reply With Quote
