Old 01-08-2017, 10:04 AM   #1
KFMFORD
Default Cam ID Help
Have small block Ford cam,trying to find make and specs,following numbers are etched on end of shaft.#6055/6050 - R5418-09-s110.0-Suppose to have been in 351w / 427 stroker.Thanks in advance for any info!!!
KFMFORD is offline   Reply With Quote
Old 01-08-2017, 11:45 AM   #2
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Default Re: Cam ID Help
Maybe somebody that worked were the made it can dissect the numbers for you but......with the small block ford stuff there are so many variables when buying used cams.
does it have common cam bearings or stepped?
Is it old nascar stuff with 55m 1-4 and 50mm rear?
if so what firing order is it?
was it ground with 41-1/2 or 45 or 42/46 lifter phasing angle?
here is what I do....measure the bearings, put it in the right block and then you can measure all the other stuff yourself and determine what stick it is
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
