Old 11-09-2016, 12:42 PM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default Bad Gas and 5.7 TPI Injectors
I left my 5.7 Formula sit for almost two years while I worked out of town. It smells and runs like it has bad gas. How do you clean the injectors of this gunk? Is there an injector I could junkyard source to replace these or just buy new ones? Or should I take them somewhere to be cleaned and flowed?
brian schuetta is offline   Reply With Quote
Old 11-09-2016, 06:01 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Bad Gas and 5.7 TPI Injectors
There are injector servicing shops that use bench top cleaning machines to flush & flow test them. You pull the injectors and take them there. Should be listed in your phone book. That is becoming pretty common.
Ed Wright 4156 SS/JA
Old 11-09-2016, 06:45 PM   #3
brian schuetta
Thanks, I'll look it up.
Old 11-09-2016, 08:01 PM   #4
jim morgan
Liked 52 Times in 9 Posts
Injector Experts fostoria Ohio
Jim Morgan 1916 , 9916 STK
jim morgan is offline   Reply With Quote
Old 11-09-2016, 10:46 PM   #5
FED 387
Liked 333 Times in 180 Posts
Sea foam or Techron. Otherwise look at Witchhunter.com
Old 11-10-2016, 10:21 AM   #6
Signman
Liked 269 Times in 99 Posts
https://fuelinjectorconnection.com/
Old 11-10-2016, 01:30 PM   #7
brian schuetta
Got quoted a price in San Antonio this morning of $160 to clean and test at Fuel Injection Specialties.
Old 11-10-2016, 04:52 PM   #8
Jeff Teuton
Liked 325 Times in 50 Posts
After you get them cleaned, put them in the car and run them. Letting injectors lay around especially after being cleaned often don't work when you need them.
Jeff Teuton 4022 STK
