Old 10-11-2016, 03:54 PM   #1
572nova
572nova's Avatar
Default Gear recommendation
I have a 69 nova weighing 3100lbs with a 572 crate engine using a TH400 with a Dana 60 and a 4.10 gear. I have a 2 speed PG with a 1.80 gear set I want to try in the car. I was thinking of using a 4.56 gear but was wondering if anyone could give me any recommendations for a gear ratio when switching from a 3 speed to a 2 speed? Thanks
572nova is offline   Reply With Quote
Old 10-14-2016, 01:46 PM   #2
prostockpete1
Liked 90 Times in 52 Posts
Default Re: Gear recommendation
Almost 300 looks & nobody has not any info / data on this gear / trans swap ? wheres all the geniuses out there that mite have wondered the result changes
prostockpete1 is offline   Reply With Quote
Old 10-14-2016, 04:41 PM   #3
james schaechter
Anyone with Prostock as their first name should have something for him. LOL!
James Schaechter 3163 STK
Old 10-14-2016, 05:18 PM   #4
Ed Wright
Ed Wright's Avatar
Which Stock or Super Stock class does that run? Might not find anybody here running anything like that. Ya think?
Ed Wright 4156 SS/JA
Old 10-14-2016, 08:36 PM   #5
572nova
572nova's Avatar
I don't run a stock or super stock class. I just figured I would ask the question here thinking that lots of super stock guys may have tried changing from 3 speeds to 2 speeds or vice versa. Talking to some racers the most common answer I have heard is to go up a couple of gears ratios when changing to a 2 speed.
Old 10-15-2016, 01:21 AM   #6
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I think I would just try what I had first then make the decision. You will then have your own data base of sorts and will not have cost you a dime...of course torque convertor selection rears it's head as well.
Rich Taylor
I/SA - 321
Old 10-15-2016, 10:38 AM   #7
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Talking Re: Gear recommendation
Who is this guy??... so impatient!
Dave Turner
SS/GT #1153
Old 10-15-2016, 02:57 PM   #8
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Maybe you should try posting this question on the correct form, such as Bracket, Top Stock or .90's tech section and take ProStock with you......................
Bob Mulry 7516 STK
A & M Motorsports
Old 10-16-2016, 11:56 AM   #9
572nova
572nova's Avatar
New to the forums here Bob and just thought that stock and super stock racers might have done more swaps. I will give the other sections a try. Thanks!
Old 10-16-2016, 12:07 PM   #10
tim worner
Liked 126 Times in 20 Posts
With all that torque and a big tire I would think a 4:56 would work . I'm sure you don't want to wind her up to high in the traps.
Tim Worner SS 1747
tim worner is offline   Reply With Quote
