Old 10-08-2016, 07:43 PM   #1
DougM
Default Stock Eliminator Heads 441 question
Thanks to all that answered my question!
Regards
Doug
DougM is offline   Reply With Quote
Old 10-08-2016, 11:18 PM   #2
Liked 1,893 Times in 423 Posts
Default Re: Stock Eliminator Heads 441 question
Yes. Just because the casting number is the same, it does not mean the casting itself is the same. There are several known versions of the 441 head in particular.
Old 10-09-2016, 12:01 PM   #3
Adger Smith
Liked 880 Times in 311 Posts
The specs that are listed in the NHRA guides may or may not be what was actually produced by the auto maker (all brands). The specs listed are the specs that NHRA Tech Department chooses to accept and publish as "NHRA's Accepted Specification". The acceptance process is usually done by what the auto maker submits to NHRA as the spec for specific engines. I believe NHRA has also altered some specs by what their Tech inspectors suggest or another long NHRA process. In short, What is published in NHRA specs may never be found in a junkyard or stack of engines. On the other hand you may find parts with the NHRA specs.
Adger Smith (Former SS)
Old 10-09-2016, 12:21 PM   #4
DougM
Thanks Adger and Alan. This information makes picking used heads even a bit more difficult. I will have to cc all heads as I am sure I will not be able to tell the difference between a 63 and a 74 cc chamber volume! Any tips on selecting used 441 castings?
Regards
Doug
Old 10-10-2016, 07:50 AM   #5
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I never saw a 441 head with anything but the large mid 70's CC chambers...
They were usually 75-76 cc's or a little larger, unmilled......
1.94-1.5 valves and there were some with 1.6 exhausts used on I believe 1970ish 400's in trucks with 3/8ths valve stems.....IIRC....
If they made a small CC version, I never saw one....
Rich Biebel
S/C 1479
Stock 147R
Old 10-10-2016, 11:19 AM   #6
Kevin Panzino
Kevin Panzino's Avatar
Liked 772 Times in 141 Posts
I too have never seen one.
Old 10-10-2016, 02:00 PM   #7
DougM
Thanks Rich and Kevin! I will ask the owner who is selling the entire motor if I can c.c. the heads and then I will report back if he is agreeable.
Regards
Doug
Old 10-10-2016, 04:05 PM   #8
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
I'd say that 63 cc head is a mis-print. I've never seen or heard of a 441 head with 63 cc chamber. You might need to call tech dir in your div. OH! You would be able to SEE the difference between 63.3 and 73.26. Big difference.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 10-10-2016, 11:20 PM   #9
DougM
Thanks Terry!
Regards
Doug
Old 10-11-2016, 09:13 AM   #10
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I would double check with tech, but I have done several different small blocks that have bee n changed from 76cc to 63.3, 75 350 w/882's is one 73-74 350's w/993's is another one that has been changed.
Can spot it pretty easy takes about .150'' angle mill reduce them to 64cc.
Mike Taylor 3601
