Liked 10 Times in 6 Posts
I've got a 68 Camaro stocker that currently has a 461 in it.I've always ran a primary pv in it when it had an automatic,it now has a stick,no changes to the engine.It's very choppy in 1st gear going thru the pits,clears up halfway thru the gear.Do you stick guys run power valves?
Sorry,I meant to post this in tech.Will the moderator please move it? Thank you.
A power valve will help but you dont want it to rupture if you ever had a backfire! I never run them have had good luck without!
Just to be clear,it does have a pv in it now,same one that it had with automatic.
Banned
Liked 179 Times in 89 Posts
Power valve is only affected by engine vacuum. and it must be closed at idle The # on the PV body is the inches of vacuum it will open.
Check the engine vacuum and use a PV a couple inches higher. Think I got it right. ![]() Last edited by Chevy55; 07-16-2016 at 07:11 PM. |
Maybe around a 3.5 PV just a guess?
Liked 33 Times in 16 Posts
I've been advised to do away with any PV...no more guess work.
Rich Taylor I/SA - 321 |
I never run them my homemade carbs get the job done!
Thanks everyone. Power valve is correct for engine,even tried a new one,cleaned out carb,blew it out,float level and fuel pressure checked.This carb worked very well with a foot braked auto,crisp and did not have the problem going thru the pits in 1st gear.Problem started with stick installation,it's choppy and surges until about 2500-3000 in first then is fine.I just wondered if the stick guys pulled the valve....I'm going to order a block off plug and up the jets......Thank you.
Liked 274 Times in 105 Posts
I am watching this question with interest.
*one thought, when driving at low speed only have the throttle open a small amount and regulate the car speed by selecting whatever gear gives the desired pit road speed. *I have experimented with power valves on gas carbs. I like the low speed performance and cleaner when staging with footbrake. With trans brake leaving where you are wide open on converter or two step I do not run a power valve. *I do know it is common with Methanol carbs to run a primary power valve. It may mostly come down to personal preference. I would like to know the % of who runs what. |
