Old 07-12-2007, 08:57 PM   #1
FED 387
Liked 332 Times in 180 Posts
Default front wheel drive slicks
Has anybody tried using a slick designed for a front wheel drive vehicle on a rear wheel drive vehicle???? What would happen if you did try it ???? Just curious--- Comp 387
Old 07-12-2007, 09:47 PM   #2
larry dowty
Liked 11 Times in 4 Posts
Default Re: front wheel drive slicks
I sold some of my slicks to a road racer with rwd he says they work great. I dont think the tire knows?
larry dowty is offline   Reply With Quote
Old 07-14-2007, 06:10 PM   #3
FED 387
141 views and nobody has tried this???? How come????
Old 07-14-2007, 09:45 PM   #4
art leong
If you are talking about the M/T slicks 20 inches and 22 inches tall. They are very very hard. They last years.
The only reason we run them is they are short and make up some for the lack of a final drive ratio.. The best I can get is 3.73 to 1 With a motor that can make power to 9,000 rpms. I'll need to run as short a tire as possible.
The M&H tires are softer, but no where near RWD tires.
I belive, If we could get a better gear ratio nobody would use them
Old 07-14-2007, 10:11 PM   #5
FED 387
Art thanx for the reply was really thinking about something in a 27 or 28 inch tall tire and about 10 inches wide, really as light in weight as possible---ratios are no real problem for me--- Thanx Comp 387
Old 07-14-2007, 10:44 PM   #6
art leong
You might try the real fast cars. I believe they run a 26 inch tall tire. I think Goodyear makes them.
I'm out of the loop with those guys.
Old 07-19-2007, 10:37 AM   #7
Bill Andrews
we run the 22in M & H slicks. Our car is a 77 olds starfire with a v6. we are having problems with not enough side wall. I was told these slicks were FWD tires, A RWD car will transfer the weight back onto them therefore crushing them. with a taller tire it shouldn't be a problem. Contact Hoosier or the manafactor of your chose for better input.
regards.
Bill Andrews 3445 STK
Bill Andrews is offline   Reply With Quote
Old 07-24-2007, 07:48 PM   #8
FED 387
330+ views and absolutely nobody has ever experimented(tried) FWD slicks on a rear wheel drive vehicle OR RWD slicks on a FWD car right????? C'mon somebody out there has right????--- Comp 387
Old 07-24-2007, 08:14 PM   #9
TOM KASCH
Liked 241 Times in 100 Posts
Smile Re: front wheel drive slicks
I raced fwd cars since 1983
no one ever ask me if they coulld run our type of tires on a rear wheel car.
But I wondered if a dragster like a vw or 6cly could because of light wt.
In 83-86 we ran Goodyear road race tires that were not slicks, they worked o.k.,
but not as good asHoosier or m/t's in the 90's-2003.
I think it would depend on the wt of your car, but WHY would you want to unless you need lots of rpm's ?
just a old man's thinking................
Old 07-24-2007, 08:22 PM   #10
FED 387
Tom--- 4 cyl dragster - rear gear ratio not much of a problem---looking for a 10x28 tire like the old Gyear 1744 Motorcycle tire--- no longer made ---want to get that unsprung weight down thought a FWD tire might be worth it but do not want to spend $400 to try it and not have it even pick up a little bit--No what I mean--- By the way great pix I remember most of those cars--- What are you guys doing now/// Have not seen your Olds out in a while--- Comp 387
