Old 07-09-2016, 02:46 PM   #1
Hans Olsson
Hans Olsson's Avatar
Default Best 1350 U-joint?
Which u-joint is the best/strongest of the 1350 kind.
Thanks.
Hans Olsson is offline   Reply With Quote
Old 07-09-2016, 03:41 PM   #2
Woodfin
Liked 288 Times in 109 Posts
Default Re: Best 1350 U-joint?
the market will have a number of acceptable options.
Strange #U1641 is a good choice. In addition, other driveshaft builders will have an equivalent part.
If you have a driveshaft shop near they will have or can get a HD 1350 series. You want a solid cross [no grease fitting nor grease channel]
Old 07-09-2016, 11:36 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Best 1350 U-joint?
I've had excellent service from Spicer solid u-joints.
LOCOMOTION Racing
Old 07-10-2016, 03:02 AM   #4
Hans Olsson
Thank you.
Old 07-12-2016, 04:04 PM   #5
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Almost any without the trunnion cross drilled for grease.....
The smaller (and more) needles the better.... You get a larger diameter trunnion and better load capacity with more needle bearings....
Bob
Bob Mulry 7516 STK
A & M Motorsports
