Old 04-18-2016, 02:12 PM   #1
colormebad
colormebad's Avatar
Question Timing retarding 2* after installing crank trigger
I'm running a 7AL-3 Black Ignition' Just installed a sbf used crank trigger..... Set the sensor with one of the magnets, locked on 30* and turned the dist to #1 ... Fired right up. Looks rock solid till I rev the engine, then it retards 2 degrees.... I have tried everything with no luck... The sensor wires match the wires going to the 7AL-3 , but reversed them and timing advanced 20 * so switched back... Crank trigger wheel is on right side' with arrow on outside turning clockwise... Sensor is about 50 airgap from trigger wheel..
Things I tried below...
Tried another but used sensor
Tried another crank trigger wheel
Tried a used digital 7
Just tried a new out of the box digital 7
Have 0 chips in retards not using and ran gnds also
Ran gnds from aluminum heads to frame
Using flaming river self powered regular timing light ' but tried 3 others
Put light on # 6 cyl and still same thing
Even though I have heavy gnd's and hot at rear and front of car, ran 10 gauge + & - from 7AL3 to batt
Intsalled a new I had laying around , shielded cable from sensor to ign box...
Timing was off 2* on balancer when I first built the motor' went back yesterday with a dial indicator in #1 cyl and made sure it was still the same...
MSD has went out of their way trying to help me but said they didn't know what else to try..
Anyone here ever have this problem ?? thanks
colormebad is offline   Reply With Quote
Old 04-19-2016, 05:05 PM   #2
Dick Butler
Liked 32 Times in 19 Posts
Default Re: Timing retarding 2* after installing crank trigger
"Set with one magnet"? Did you center it or use leading edge? On magnet old Moroso that was method. Putting at starting pt w loose timing belt? Did you use other style timing light too?
Old 04-19-2016, 05:47 PM   #3
colormebad
colormebad's Avatar
I centered it with one of the magnets and locked it down on 30*
Then pointed the rotor toward #1
I did have to moved the sensor a few times to get it dead on 30....
Then when u go back and check it, the censor and magnet is not centered with each other.... MSD said that was normal.... When it fires its dead on 30* still as can be till you rev it up and then it retards 2*
Old 06-03-2016, 08:48 PM   #4
colormebad
colormebad's Avatar
Just shot a video clip, you can see what its doing...Starts retarding around the 12 sec mark a few times when I rev it
Old 06-03-2016, 08:56 PM   #5
FED 387
Liked 335 Times in 182 Posts
you using a timing chain or a gear drive? FED 387
Old 06-03-2016, 09:58 PM   #6
colormebad
colormebad's Avatar
Chain
Old 06-06-2016, 04:49 PM   #7
1968 SS
1968 SS's Avatar
Normal operation of MSD 7AL-3 ignition box to retard timming up to 4*
Set timming at 3,000 RPM as per MSD instructions.
Brian
1968 SS is offline   Reply With Quote
Old 06-09-2016, 12:30 PM   #8
FED 387
Most chain driven cams will retard when you rev the engine and then let the RPM's come back down its the play/slack in the chain doing it---just like what yours is doing--- suggestion---- rev the engine to say 4000 RPM -5000 RPM hold the rpm steady then hold the timing light on the balancer mark move your distributor or pick up on the crank trigger whatever you do to set the timing to the desired timing -- tighten down your pick up or distributor---then recheck the timing again at say 4000 see if it stays where you set it or if it moves- revving and then letting the RPM go up and down allows the chain to advance and retard the timing as the chain loosens and tightens--- make sense??? FED 387
Old 06-09-2016, 12:49 PM   #9
pmrphil
Liked 397 Times in 153 Posts
The timing chain has nothing to do with timing when using a crank trigger, only affects the position of the rotor. I just adjusted for it so it was correct at RPM. Sure does make you wonder, huh?
Phil Molski
PMR Performance
S/C 1623
Old 06-09-2016, 01:22 PM   #10
colormebad
colormebad's Avatar
I just noticed the crank trigger bracket is Vibrating pretty good when I rev the engine to a certain rpm, which is causing the timing mark not to be rock steady as it should .... Now I wonder if that is also where the 2* retard is coming from... Just ordered a bracket , so I can mount it to the motor instead of the motor plate.... This was a used bracket that someone used on the driver side, and had cut one side off some... The bracket I made to mount the bracket that came with the kit to the motor' Is and looks strong, I don't see how its doing what I see with my eyes.... I still hope its not a problem with the balancer...The bracket that mounts to the stock location timing pointer , will be here later I hope...
