Old 06-28-2016, 08:21 AM   #1
Danny Ashley
Liked 110 Times in 29 Posts
Default Metric 200 question
What is the preferred distance between the flexplate and convertor pads when the convertor is all the way engaged in the pump? I know it's less than the other turbo's and am thinking A-1 told me a few years back around .100. Just want to make sure. Thanks for your response.
Danny Ashley is offline   Reply With Quote
Old 06-28-2016, 08:35 AM   #2
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Re: Metric 200 question
all depends on the over all height of the converter.1/8 to 1/4 at the most.As long as the hub is still all the way in the pump gear all should be good.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 06-28-2016, 06:55 PM   #3
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
Basically you want the converter about an 1/8 inch from bottoming out on the pump lugs.With the converter bottomed out on the pump, measure the lug to flexplate distance, subtract 1/8 inch (.125) and that is the spacer(s) needed. That is how I installed mine and no issues.
Mike Moller
NHRA 203 Q-R-T/SA
