Liked 19 Times in 7 Posts
Im assuming this thing shifts off output shaft rpm so previously i had a spring and weight combination to shift at 6500 with a 2.52 low gear. If i was to change to a 2.75 low gear, the driveshaft speed would be lower at 6500rpm and make the trans shift the 1-2 at a higher rpm correct? Check my math for me and see if im even thinking correctly:
6500rpm ÷ 2.52 = 2579 output shaft speed 2579rpm output shaft speed × 2.75 = approx 7100rpm 1-2 shift Please tell me if this sounds correct.
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
Liked 239 Times in 114 Posts
Your math is correct , but remember that the valve body shifts based on governor pressure, which is based on governor rpm, which is spun by the output shaft . Once the shift valve shifts, it takes a moment to fill the clutch circuit and actually shift the transmission . Typically a 2.75 ratio is gaining rpm quicker than a 2.52 ratio trans, so to get the same shift point (6500) you may need to lead the shift point more than with the 2.52 ratio . Also the shape of the governor curve is much steeper on the early part of a governor curve than the later part of the curve. It is not a straight line . So the way I basically calibrate a governor is to use the weight to dial in the 1-2 shift, and the spring to fine tune the 2-3 shift . If going from a 2.52 to a 2.75 ratio, you will need heavier Secondary weights, and see where that takes you , before making any changes to the secondary springs . If this is a 350 trans, do these changes in pairs , same weights, same springs, don't mix .
