My buddy's 350 lost both ends of a pushrod and there is no oil coming out of any of the push-rods/ rockers. He revved it up to about 2000 without any oil coming out. It has about 30# at 2000, about 15 at idle. Any thoughts?
old 1608 stock racer |
Liked 1,795 Times in 409 Posts
Not enough information.
Already running for X amount of time? New build? Any changes? Street engine? Race engine? Cam and lifter type and brand?
Alan Roehrich 212A G/S |
Car was bought with rebuilt street engine with blower, about 2000 miles on it. No oil on either of the heads. Don't know what type of valve train it has. Going to pull the engine and see what is up. Will post when we get that far and ask what we should be looking for. Still open for advice. Thanks
Liked 3 Times in 1 Post
Is that 30# oil pressure at 2000rpm if so you should have 60 to 80#
oil pressure. Looks like main brg too much clearance or they are bad. |
#5 | |
Liked 18 Times in 10 Posts
Make sure the galley plugs are installed in back of the timing gear. |
Liked 99 Times in 49 Posts
Liked 129 Times in 59 Posts
By-pass on the oil filter adapter?
You also might want to check and see if the previous owner might have installed oil restricters in the lifter feed oil galleys at the back of the motor. Hope you find your problem!
Lew Silverman #2070 "The Wagon Master" N/SA |
Banned
Liked 5 Times in 3 Posts
If the pushrod oil feed hole in the lifter isn't in the band of the lifter or doesn't have a groove machined from the band to the oil feed hole this could be your issue, sometimes the lifter bore clearance isn't enough if the feed hole isn't in the band. Just some more places to look...
Liked 358 Times in 83 Posts
It's not a Bowtie block, is it? Because with those, engine builders have been known to forget to reinstall the galley plug that feeds the cam tunnel, which causes seemingly unexplained, but repeated (until you figure it out) cam bearing and lifter failures, due to lack of oil. Obviously, if the camshaft isn't getting any oil, the pushrods and rocker arms won't, either.
