Old 05-26-2016, 08:58 PM   #1
J&S Racing
Liked 319 Times in 82 Posts
Default Apd throttle stop problem
Has anyone running this set up had issues with the stop being inconsistent coming on?? Seems the first couple times I cycle the stop it hangs up closing then seems fine for a few hits then will hang up again... I have changed the solenoid & distribution block and it still does it.
Old 05-28-2016, 06:28 AM   #2
sst5167
sst5167's Avatar
Liked 17 Times in 9 Posts
Default Re: Apd throttle stop problem
I have installed the Max Speed carbs on 5 different cars. I also have them on two of my own cars and have never seen this. I'm sure you've already checked the basics:
Is anything binding?
Is it hitting a SLE?
Good CO2 bottle pressure?
I wouldn't hesitate to call the guys at APD. I bet I've made a dozen calls there with some really dumb questions, and they've always been great to work with.
Good luck, and let us know what you find out to be the problem.
sst5167 is offline   Reply With Quote
Old 05-28-2016, 08:25 AM   #3
J&S Racing
Ended up putting a few drops of air tool oil in the small adjusters on the ram and it seemed to solve the problem
Old 05-28-2016, 08:40 AM   #4
J&S Racing
Actually it wasn't that it was hanging up....The first few hits were normal then it would slam closed at full speed several times then normal intermittently.There must have been a dried out o ring in the adjuster.
Old 05-30-2016, 07:20 AM   #5
sst5167
sst5167's Avatar
Glad to hear you found the problem. Good luck with it, I have had great luck with them!
