Old 04-01-2016, 08:43 AM   #1
Brian Oakes
Liked 439 Times in 116 Posts
Default pro's and con's on 16v. GoLithium battery
anyone using on of these battery's and how good are they. Thanks Brian
Brian Oakes is offline   Reply With Quote
Old 04-01-2016, 11:22 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,985 Times in 598 Posts
Default Re: pro's and con's on 16v. GoLithium battery
Brian
I have been using one since the Immokalee race. So far it has performed flawlessly. I bought the battery, charger and mounting bracket. The battery charges quickly after each run and uses about 20% of the capacity on a run. It's usually fully charged after 20 minutes after a run. One thing I have done is use a separate battery to run my fan and water pump when I cool down after a run. The charger for the lithium batter is designed to charge the batter only and not run the fan and pump
At the same time. I have a separate 16 V battery and I made a pigtail to plug in to my cooling system. The battery and mount weigh 10 lbs. that was 40 lbs weight savings over my 16 v lead acid battery. go Lithium said properly maintained the battery should last 10 seasons. I would recommend it based on my experience so far.
Mike Pearson 2485 SS
Old 04-01-2016, 04:54 PM   #3
chester
hey quack, go on a diet and save 700.00, chuck
chester is offline   Reply With Quote
Old 04-02-2016, 04:43 PM   #4
Doug Walker
Doug Walker's Avatar
There has been a 16 volt Braille battery in Matt Welker's SS/AH Barracuda since last year. Check with him.
Old 04-02-2016, 07:48 PM   #5
Matt Welker
Liked 77 Times in 15 Posts
Brian,
Email me, I tell you who to speak with at Braille with any questions. We have them in all three cars, alt, no alt, every setup.
The new ones have 33% more power than the ones we are running.
You won't have an issue and won't even need to keep a charger on it while your on the rig for months.
matt@welkerlawfirm.com
410-507-2837
Matt Welker
Stock 1741, SS/AH 114
www.facebook.com/welkerracing
Matt Welker is offline   Reply With Quote
