Old 03-31-2016, 08:39 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Default Aeromotive Fuel Pressure Inconsistency Part 2
For clarification this may help......the fuel pressure always holds steady once the engine is started until it is shut down.......it never restarts at the same pressure but it holds at whatever it starts at, there is no fluctuation while running. Set at 6 while running and holds forever until shut down that is great.... BUT it will restart with more or less fuel pressure and hold until readjusted or shutdown. Checked the voltage, the vent, the fuel is dumping on foam and the fuel cell is kept full. Open to any and all help. I am running a filter before the fuel cell and another a couple of feet from the carburetor. The Aeromotive gauge at the carb always agrees with the Autometer on the cowl. Thanks for any comments. Interesting note......Aeromotive told me I didn't have a problem-----really ???
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 03-31-2016, 10:08 AM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Aeromotive Fuel Pressure Inconsistency Part 2
Rusty,
I reread your other post so I hope I did not miss something there. Explain your layout and where the pump,regulator and cell are along with fittings and line sizing. The reference port on the regulator diaphragm is open to atmosphere right? If this is plugged or blocked that could play a role as the regulator warms and cools it will change your setting.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-31-2016, 07:42 PM   #3
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
The fuel return should not be dumping on the foam...
The return should be submerged so the returning fuel does not cause foaming..
Bob Mulry 7516 STK
A & M Motorsports
Old 03-31-2016, 11:01 PM   #4
Kevin Panzino
Kevin Panzino's Avatar
Liked 774 Times in 142 Posts
Could be an instrument hysteresis or "stiction" issue and nothing more.
