03-07-2016, 03:31 PM | #1 |
Pro Tree T-Brake Vs. Full Tree T-Brake in SS
Is there a performance advantage to using a certain kind of transbrake in Super Stock?
03-07-2016, 05:42 PM | #2 |
Liked 675 Times in 267 Posts
Re: Pro Tree T-Brake Vs. Full Tree T-Brake in SS
When I went from a old TCI valve body to a Griner valve body I was .035 faster with Griner. Everything else in car was the same.
03-07-2016, 08:46 PM | #3 |
Liked 389 Times in 168 Posts
I have had three transmissions in mine, I won't name the other names, but whatever the Smiths put in my Pro Trans is faster than the other stuff I had. Only button I can find slow enough, even using a blinder, is the Just-N-Time button.
Best transmission I ever ownned as well.
Ed Wright 4156 SS/JA |
03-08-2016, 08:26 AM | #4 |
Do you guys mean faster in reaction time or ET?
03-08-2016, 11:48 AM | #5 |
Liked 89 Times in 46 Posts
Is "faster" by dumping the reverse fluid quicker?
03-08-2016, 12:44 PM | #6 |
03-08-2016, 02:05 PM | #7 |
The Pro Trans made the car faster, but I was referring to my lights. Suddenly going red with my old button.
03-09-2016, 08:27 AM | #8 |
Okay thanks guys!
03-09-2016, 04:23 PM | #9 |
Liked 525 Times in 138 Posts
Also - you can make your own adjustable button
When I raced super-gas I made my own trans brake buttons from surplus snap switches available at a local electronic store for about $2.50 a piece.
This is a similar one that can be ordered for about $9.00. I just made my own shims to change the length of the button travel. I could red light easy when used with little travel. |
03-12-2016, 11:07 AM | #10 |
Liked 703 Times in 206 Posts
Pro Tree brakes are typically fluid exhaust , meaning they rely on line pressure to move the valve when the solenoid releases . .....They are really intended for the Super .90 classes . makes it hard to not go red on a full tree .
They typically us much higher line pressure than a spring actuated valve . Higher line pressure = more HP consumption = slower ET's !
