Old 02-24-2016, 09:19 AM   #1
JP Schuster
Default Radiator for SS
Are you allowed to run any radiator as long as the dimensions are the same and it fits in the stock location? In other words, can I run an aluminum replacement radiator with 2 electric fans (built on shroud) or does it have to be the stock radiator with the option of electric fans?
JP Schuster is offline   Reply With Quote
Old 02-24-2016, 01:48 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Radiator for SS
Here's what the book says:
RADIATOR
Full-size stock radiator mandatory for body used. Aluminum radiators permitted; must retain stock dimensions and appearance. Cutting, denting, or elimination of any body, fender, radiator, or grille panels prohibited.
In other words, you can't substitute a transmission cooler or aircraft radiator for a radiator on a BBC.
Dale
Dale Shearon
68 Mustang 6394
Old 02-24-2016, 02:32 PM   #3
JP Schuster
Okay thanks! I wasn't sure how close it had to look to the stock radiator.
Old 02-24-2016, 04:13 PM   #4
Jim Caughlin
Liked 805 Times in 245 Posts
This rule gets interpreted pretty loosely. Don't modify the core support to make changes. Don't switch to a cross flow if not orig configuration. You can use a 6 cyl size radiator. I think in general, as long as it looks basically stock, you won't get dinged for it.
Jim Caughlin is offline   Reply With Quote
Old 02-24-2016, 05:22 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,934 Times in 581 Posts
This
Mike Pearson 2485 SS
