Old 10-27-2015, 11:41 PM   #1
Runner493
Default Big Block Mopar dual line external oiling?
Hey all..I went and done it and stepped up to a bigger motor. It has dual line external oil pickup. I'm new to this. I'm looking at the motor and where it sits, it looks like where the oil pump cover where the fitting comes out, is gonna hit the motor mount spot on the k frame. Im hoping to do this without buying a differnt oil pump cover if at all possible. This is on a 69 b-body. any help is greatly appreciated and if its in the wrong section i apologize.
Thanks!
Runner493 is offline   Reply With Quote
Old 10-28-2015, 03:27 AM   #2
GTX JOHN
Liked 2,486 Times in 697 Posts
Default Re: Big Block Mopar dual line external oiling?
Seems like I ALWAYS had to grind the heck out of the motor mount
to make it work 30 years ago with the Milodon System. I run a single line
now (Never go over 7500 with bracket stuff) if I use stock mounts rather than Plate. Do you have Hemi or Wedge as mounts are completely different?
Any engine powerful enough to need a dual line system.................Would
generally be fast enough for a engine plate.
John Irving
741 Stock
741 Super Stock
Old 10-28-2015, 09:12 AM   #3
Runner493
Hey thanks for replying. .john I have wedge..493 low deck.
Old 10-28-2015, 02:37 PM   #4
VanPelt
VanPelt's Avatar
I had a plate in my last wedge. No problem with oil lines at all.
Happy Racing.
VanPelt is offline   Reply With Quote
Old 10-28-2015, 08:34 PM   #5
Runner493
Well I need too figure out how to get my pictures up and show what I have. .theres no way it's gonna sit in there how the fitting comes out of the oil pump
Old 10-30-2015, 12:54 AM   #6
GTX JOHN
Do you need Dual line....Single Line works fine to about 7500 RPM and
that is a LOT for a bracket 493 and way better than stock oiling system
in the block!!
Plate is easy to install unless you have Air Conditioning and Power Steering and twin turbos
John Irving
741 Stock
741 Super Stock
Old 10-30-2015, 01:25 AM   #7
Runner493
testing seeing how this if i got this to size to work...no i problaby dont need a dual system but it came with the motor that i bought
Old 10-30-2015, 10:14 PM   #8
James L Miller
Liked 25 Times in 16 Posts
Milodon has two covers that the oil line goes in straight instead from the back. One is for remote filters and one has the oil filter base built in.
http://www.manciniracing.com/mibiwealoilp.html
Mopar 2 Ya!
Old 11-03-2015, 01:36 AM   #9
Runner493
Shoot looks like that's gonna have to be the way to go..anyone got one of those laying around? Lol. Thanks for everyone's help..greatly appreciated!
Old 11-03-2015, 11:43 AM   #10
rickseeman
rickseeman's Avatar
Liked 2 Times in 2 Posts
I have had several 65-68 cars with that system. It doesn't look like it will work but it does. When you get thru torching the stock motor bracket to fit the lines there's not much left of it. But that's how people did it in the 70's and 80's. They also used a torque strap to catch the motor in case the motor mount failed.
rickseeman is offline   Reply With Quote
