Liked 351 Times in 76 Posts
Does anyone use a rubber or nylon snubber under upper control arm to limit travel, or any suggestions ?
Liked 1,916 Times in 574 Posts
I use a poly snubber similar to a traction bar snubber. I have it mounted to a 5/8 stud so I can adjust it up and down. I have a 5/8 nut welded to the upper a arm then use a jam nut on the top. I have the same snubber on the lower a arm as well
Mike Pearson 2485 SS |
Thanks for the reply Mike, your idea sounds a lot better than mine, I wasn't thinking about the ease of adjustability, where did you get the snubbers from? Thanks Dale H
Liked 2,466 Times in 695 Posts
Summit sell a large number of different designs........Many easy to cut for
your need application.
