Old 08-07-2015, 11:20 AM   #1
Bryan Worner
Liked 535 Times in 86 Posts
Default Throttle body
If you were building a 1990-1992 Chevy 350 (245/275) for Stock or Super Stock, utilizing the NHRA Engine Blueprint Specification Guideline and Stock Car Classification guidelines, what throttle body would you "legally" use?
Bryan Worner is offline   Reply With Quote
Old 08-07-2015, 07:13 PM   #2
magnumv8
Default Re: Throttle body
In the blueprint specs all the way to the right of the engine choice depending on year you will see either a number 1 or 2....go to the bottom and it says that the 2 x 1.889" (48 mm ) throttle body is the legal one..........D L Rambo...STK 1300
magnumv8 is offline   Reply With Quote
Old 08-07-2015, 08:58 PM   #3
Jeff Teuton
Liked 325 Times in 50 Posts
I was told quite recently that OEM throttle bodies only in stock and super stock. I was asking if specs say 80 mm, can I use any. Answer was no. Just sayin.
Jeff Teuton 4022 STK
Old 08-07-2015, 09:55 PM   #4
Paul Hellenberg
As far as I know all the GM 2 port throttle bodies are more of less the same spec. The publish size is in the blue print specs. Some of the TB have slightly different throttle attachments.
Paul Hellenberg
3881 SS and STK
paul@hellenberg.us
Paul Hellenberg is offline   Reply With Quote
Old 08-08-2015, 10:35 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
There are generally only two TBI sizes. One is a 1 11/16" bore that is used on 4.2, 5.0 and 5.7 engines and the other is a 2" bore used on 454 engines.
Sorry! I pulled the trigger to quickly. I thought you were talking about TBI engines.
Old 08-09-2015, 08:23 AM   #6
Herbie Null
Herbie Null's Avatar
Liked 439 Times in 69 Posts
Talking Re: Throttle body
The spec sheet does not list a part number, all it has is N/A. In the notes it says 2 @ 1.889 48MM, so I guess you can build your own throttle body just make sure its 48MM
Herbie Null 201 SS
Herbie Null is offline   Reply With Quote
