Liked 20 Times in 15 Posts
Any good machine shops in the Philly and surrounding areas that regrind cams?
Liked 126 Times in 61 Posts
The manufacturers are very reasonable in charges with a quick turn around.
Liked 335 Times in 182 Posts
check with the manufacturers also if the cam has been hardened many cam grinders might not want to do the work--- we used a Company in the Carolinas hafta look thru my notes I'll get their contact info--FED387
I'm just trying to see if a stock regrind will be cheaper on my Dime Rocket. Thanks
Liked 99 Times in 21 Posts
The biggest issue that you're going to run into with a stock regrind is going to be the inability to change the lobe separation. I'm sure that it is going to want to be tighter than stock.
If you do insist on doing one though, I have dealt with Camcraft before. They'll do the best that they can for you!
Liked 2,493 Times in 700 Posts
For our Mopar stuff we found for a Stocker the cam was
one of the worst areas to try and cut corners. The are a significant part of how well the car performs.
In Baltimore not that far away is Racer Brown Cams 410-866-7660 ask for Jim
