Old 06-30-2015, 10:41 AM   #1
BWill
Default Q Jet questions
How far should the sec. throttle plates open on a stock GM intake?, and how far on an open plenum intake. I know there is a measurement for the sec. air valve door opening, anybody have that number?, thanks
BWill is offline   Reply With Quote
Old 07-02-2015, 11:46 AM   #2
tj310
Default Re: Q Jet questions
Throttle plate 90* +or - 5
Air valve most look like like they should open a little more .
When I did test carbs back to back I didn't find any topend gain.
---Trevor
Old 07-02-2015, 03:28 PM   #3
Jim Hanig
Liked 99 Times in 49 Posts
I spent days fooling with it on the dyno never found anything unless u got it way out .Then it hurt the power.
Old 07-03-2015, 09:32 PM   #4
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hard to test a Q-Jet on a dyno because most of them don't have wheels...
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 07-07-2015, 08:28 AM   #5
Jim Hanig
Evan harder if you race track is a 100 miles away.
Old 07-07-2015, 11:08 AM   #6
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Bob
You mean the Flintstone Dyno Test !!
Old 07-09-2015, 05:14 PM   #7
Bob Mulry
Bob Mulry's Avatar
Only a hundred miles away...........
That's like having a Drag Strip in your back yard......
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 07-09-2015, 07:36 PM   #8
JRyan
Liked 112 Times in 31 Posts
Bob,
Jim is used to having one in his back yard (Houston). Now back in SoDak, that's no longer the case.
Jerry
Old 07-11-2015, 10:36 AM   #9
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Secondary air door, 1.280 - 1.320 from the back of the air horn to top of secondary air door.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
