Old 06-01-2015, 10:54 PM   #1
Darrin Christen
Darrin Christen's Avatar
Default MSD Power Grid + 7AL2
Anyone using a 7AL-2 with a Power Grid? I have noticed that while on the launch rev limiter the rpm is very rough or erratic. The Racepak shows the rpm jumping around 300-400 rpm. For example if I set the rpm at 3200 the car may leave at 3200 or 3500. I previously ran the 7AL-2 with a 3 Step and it was a lot smoother. Has anyone else noticed this?
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 06-02-2015, 09:07 AM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: MSD Power Grid + 7AL2
Though I'm not certain, perhaps a change in RPM limiting strategy? The number of hits and misses may be different in the grid, perhaps it's something you can change? As I've never used one I'm merely guessing but that may be something to look into. Joe
Joe Buchanan SS/BX 3117
Old 06-02-2015, 11:44 PM   #3
Average Joe
Liked 18 Times in 8 Posts
Are you using the rev limits in the grid controller or the chips in the 7al-2? MSD acknowledges a harsh rev limit if you use the rev limits function in the grid and recommend using the chips in the 7al boxes when using the grid.
Average Joe is offline   Reply With Quote
Old 06-03-2015, 01:11 AM   #4
Darrin Christen
Thanks for the replies. Yes I'm using the rev limits in the Grid controller. I actually spoke to a MSD rep on the midway explaining my issue. He could not explain why it was so rough but suggested I go back to using my three step instead of the Grid Controller for the rev limits. I'm assuming this is not an issue when using the complete Grid ignition system?
Old 06-03-2015, 09:35 PM   #5
Average Joe
That is the reason why I bit the bullet and bought boy the 7730 and 7720. It is a much cleaner setup to install that way and then your rev limits will work just fine via the grid controller.
Old 06-05-2015, 12:29 PM   #6
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
We run that exact thing on our comp car and I noticed the same thing. What I did was Set all the RPM Limiters to 12,000 RPM and piggy backed a regular 2 step on the grid. Problem solved.
With ours being a 4 cyl Comp car when the 2 step from the Grid Box came in, the whole car would rock back and forth.
I was told it had something to do with the Grid box being digital and the 7AL being Analog.
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
Old 06-05-2015, 02:04 PM   #7
Darrin Christen
Thanks everyone for the help. Time to make a decision to go back to the old rev limiter or spend some $ on the rest of the grid system and sell off the 7al stuff.
