Old 06-09-2015, 11:03 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Modifying motor mounts
I have an opportunity to purchase a legal IHRA crate motor car as a roller. The factory motor mounts were removed for a motor plate. Can I just weld some steel that resembles the factory mounts or do I need to change the K member.Did not see anything is the rule book that could shed some light. This is for a Mopar.
House of Darts is offline   Reply With Quote
Old 06-11-2015, 06:45 PM   #2
magnumv8
Default Re: Modifying motor mounts
As long as the engine is still in it's original location you can just make new mounting brackets to attach it to the original k member.....mocking up a bare block and trans will get you where you need to be just make sure to get the overall height correct......
D L Rambo...Stk 1300
magnumv8 is offline   Reply With Quote
