Old 04-18-2015, 07:39 PM   #1
rod
Liked 20 Times in 15 Posts
Default Comp. Ratio ?s
I was figuring the Comp. ratio for a bracket engine. I have these question for you smart math guys.
1. when figuring the volume of the cylinder, shouldn't you add for valve notches and subtract for the dome when the piston is at BDC?
2. since the valve notches are in the cylinder at both BDC and TDC, then they should be added into to the total volume, right? or because they are there at BDC and TDC and thus cancel out.
3. since the dome is displacing at BDC, but not in the cylinder at TDC, how do you deal with that?
anything else you want to add, please do.
Thanks Rod in AZ
rod is offline   Reply With Quote
Old 04-18-2015, 09:03 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: Comp. Ratio ?s
Wallace Racing.com has some good calculators for this.
Old 04-18-2015, 09:06 PM   #3
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi,
It's the large total volume (BDC) forced into the small volume (TDC).....
The reliefs and the domes make up the total volume at BDC and TDC after that it's just division to come up with the CR...
Subtract the reliefs and add the dome to a flat top for the correct number and don't forget the gasket thickness and bore diameter of the gasket..
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 04-19-2015, 01:01 PM   #4
Liked 10,936 Times in 2,259 Posts
The Eagle rod web site has a C/R feature that is fun to play with.
