Old 03-21-2015, 08:38 AM   #1
dwg4859
Default trans cooler
Do I run a transmission cooler and if so where do I put it when I bought the transmission the lines were just a tube from one port to the other.
dwg4859 is offline   Reply With Quote
Old 03-21-2015, 11:23 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: trans cooler
Yes and anywhere it will fit. They are small. Mine is just attached to the front of the radiator with stainless steel zip ties. Putting a temp sender and gauge in is a good idea, too. I don't know what trans you have, but a lot of us have several thousand tied up in a competition built automatic and it's next to know what's going on in there. Mine came with a cooler from TCI. Performance Automatic includes them with their builds too, I believe. Cheap insurance.
Dale
Old 03-21-2015, 11:54 AM   #3
Ed Wright
Ed Wright's Avatar
Both my Rossler and Pro Trans are bypassed internally. Plugs in the holes where the fittings go.
Ed Wright 4156 SS/JA
Old 03-21-2015, 12:27 PM   #4
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I don't see the need in my application. Short duration and plenty of time between rounds...just another piece of equipment to fail or worry with.
Rich Taylor
I/SA - 321
Old 03-21-2015, 12:31 PM   #5
dwg4859
its a 200 metric in a hsa nova i just bought it going from the 350.
Old 03-21-2015, 01:05 PM   #6
HandOverFist
Mine is as well.
Rich Taylor
I/SA - 321
Old 03-21-2015, 05:38 PM   #7
GTX JOHN
Liked 2,493 Times in 700 Posts
Nothing in our stock super stock cars but a loop of tubing.
This is how ProTrans ships them and they are the builders.
In our bracket cars that run back to back a bunch of the time in Vegas.......
we run a decent to large one in front of radiator on every car!
John Irving
741 Stock
741 Super Stock
Old 03-21-2015, 07:01 PM   #8
ATI Performance Products
Sponsor
ATI Performance Products's Avatar
Liked 9 Times in 1 Post
We run one on the Challenger since the 904 is small and light with all aluminum parts. I don't need it at the races (except when I went a few rounds in a row at some shortened races) but when we are testing the Challenger can run 5+ passes in a row, and the trans will get to 200+. The Super F Synthetic fluid over Conventional Type F gets us that far as with regular non synthetic it was 200 after 3 passes. I have the cooler mounted under the car, facing the ground and it has a fan on it. Its the Derale "atomic" cool that we stock.
I don't have a cooler in the COPO since we can't cool the engine and blower off fast enough to worry about it, and its a T400 with more capacity.
You can be bybassed in the pump and just plug holes as mentioned or loop the lines. I keep a loop on the COPO so I can monitor cooler pressure.
ATI Racing
ATI Performance Products is offline   Reply With Quote
Old 03-21-2015, 08:08 PM   #9
Liked 1,914 Times in 429 Posts
I have never liked the internal bypass, ours have a small loop of tubing. I replaced an internal bypass pump with regular pump and an external bypass and dropped 4% slippage with an ATI 8" converter. Haven't run an internal bypass since.
Old 03-21-2015, 09:54 PM   #10
Kegracing
Do you plan on winning?
Not trying to be a smart butt. Most time trials and early rounds of stock/super stock have plenty of time to cool everything... sometimes a single round in a day.
However, if you plan on winning, then often the final 2 or 3 rounds are rushed, round robin, get it over.
Is a really bad feeling to get that far, that close, and have a trans hot and change your reaction time and or time slip...? It happens.
I ran without a cooler a few years ago, after having a rubber line on the barbed fitting leak in the waterbox at a divisional race in my 10.90 car. Thought it was the one less thing to go wrong or worry about. Then I lost a race when trans was hot and cost me a few hundreds in a final... stock metric 200 pans do not hold much fluid...
Now I run one of the Jegs' coolers, part # 60351 I think. I put AN fittings on it, and all braided line. Very little chance of this style cooler leaking or getting damaged. This along with synthetic fluid keeps things very consistent. Extends trans life also. Just my nickle worth of experience over the years.
Good luck.
Ken
Stock 412
Kegracing is offline   Reply With Quote
