Old 01-20-2015, 10:04 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default SBC Super 10 timing chain
I will soon need a timing system for the Super 10. I will consider a belt drive but am leaning toward a chain.
What to y'all like?
Larry Woodfin 471W
Old 01-20-2015, 10:39 PM   #2
Tom Meyer
Liked 354 Times in 120 Posts
Default Re: SBC Super 10 timing chain
Belt all the way. Easy to do the cam timing, gets rid of harmonics in the valve train and they look cool. Tom
Tom Meyer 5240 SS Stock ???
Old 01-20-2015, 11:09 PM   #3
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Jesel belt drive.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 01-20-2015, 11:14 PM   #4
Liked 1,893 Times in 423 Posts
Jesel belt.
Old 01-20-2015, 11:28 PM   #5
Ed Wright
Ed Wright's Avatar
I agree, Jesel belt. If you can't afford that, think about a Rollmaster. Billet gears, needle thrust bearing behind the cam gear. IMHO, nicer than Cloyes. Scoggin Dickey sells them. If you can swing it, get a Jesel belt.
Ed Wright 4156 SS/JA
Old 01-21-2015, 08:56 AM   #6
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Belt is cleaner, looks cool. But CTPO, no power advantage. I have been involved in fourteen different A-B-A tests with Jesel belt vs quality chain and gear and the results I have seen point to the chain making a hair's width more power. Also, no difference in harmonics as measured electronically for vibration and or sonic changes.
Ed's suggestion for the Rollmaster is good. They also manufacture a chain set that allows for timing changes without removing gears.
Old 01-21-2015, 10:23 AM   #7
Dragsinger
Thanks to all for the feedback.
And speaking of the Roll Master products I have run several sets of those with excellent results.
For my situation I think it is a good choice.
Larry Woodfin 471W
Old 01-21-2015, 10:28 AM   #8
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I use Cloyes because I can always get a replacement chain later,haven't had that good of luck getting replacement chains with others,seemed like everytime I needed one they had changed to different chain.
I like the hex-adjust they also have the other one can't think of name where outside of gear moves like the rollmaster pictured.
I like Jesel belt,really good to dyno and test cam timing in the car and cam swaps, I had A-B tested a few with no gain I could see,wasn't sure if what I was testing on was to mild to have enough harmonics to make a difference.
Mike Taylor 3601
Old 01-21-2015, 10:38 AM   #9
Signman
Liked 269 Times in 99 Posts
Dwight
Have been looking at this type of timing set for a while and connot verify if this or another part number is compatable with step nose cam.
Old 01-21-2015, 11:48 AM   #10
Ed Wright
Ed Wright's Avatar
Originally Posted by Signman View Post
Dwight
I ran them on factory roller blocks with the step on the nose of the cam. Just call the performance counter at Scoggin Dickey parts. They are located in Lubock, TX. Great guys to deal with. I don't have their number in my phone, but you can google them.
They had them in stock whenever I needed them. I saw zero gain when I bought my Jesel either. Saw nothing other than not having to pull the dampener, timing cover or water pump to move the cam.
