Old 11-18-2014, 01:52 PM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default LT-1 freshen-up
Planning on a ring freshen up on my LT-1 shortblock this winter. I do not intend to replace pistons, so I am looking for advice on rings/honing process. The motor has Lunati L350 pistons with 1/16, 1/16, 3/16 ring grooves.
I would like to consider a range of options and pros/cons for each.
I reviewed a lot of the old threads on here, just looking for latest thinking.
Total Seal recommended AP gapless top, Napier second, low tension oil.
Saw good/bad input on gapless.
Interested to hear input. This is not a high dollar deal. I am willing to spend a few bucks, but I don't want to break the bank. I also realize you get what you pay for.
Thanks for advise/input.
I have access to a couple great shops to perform the honing properly.
Thanks,
John
John Nechiporchik is offline   Reply With Quote
Old 11-18-2014, 03:19 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,919 Times in 576 Posts
Default Re: LT-1 freshen-up
Stay away from the gapless rings. They caused me to freshen my engine after one run. Total Seal could not tell me why the rings failed after just one pass. Other than that Total Seal should be able to steer you in the right direction. I have had good luck with their more standard ring packages. Make sure that you have a good machine shop that is experienced with racing engines hone the block and has a honing plate for your block
Mike Pearson 2485 SS
Old 11-18-2014, 03:24 PM   #3
Liked 10,687 Times in 2,225 Posts
I don't think you can go wrong with Greg Luneack at Tri City Competition.
Old 11-18-2014, 03:33 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,174 Times in 971 Posts
If you're at location shown on your profile I'd just jump on I-75 South to Dayton and give Bruce Parsons your stuff....A1 job. Agree with Mike on the Gapless but each engine builder has their own unique take on a ring package and it could very well be influenced by your current pistons if you're intent on using them.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-18-2014, 06:25 PM   #5
Tony Goodman
Liked 18 Times in 4 Posts
Like Larry said, I don't think you can go wrong with Greg Luneack.
Tony Goodman is offline   Reply With Quote
Old 11-18-2014, 06:36 PM   #6
richie 2
Liked 205 Times in 93 Posts
a wet mag test on the crank and rods...hundred dollar investment to be assured of crack free, highly stressed components.
Old 11-19-2014, 10:01 AM   #7
Darcy Clarke
Liked 511 Times in 35 Posts
X3 on Gregg Luneack's rings as I machined a LT1 for a friend and used Gregg's rings and they work awesome. I am currently machining another one for my Daughter and I am using the same ring package. Give Gregg a call you'll be happy with the price and service.
Darcy Clarke
6254
A/SA SS/JA
Darcy Clarke is offline   Reply With Quote
Old 11-19-2014, 10:23 AM   #8
John Dinkel
Liked 263 Times in 68 Posts
Thumbs up Re: LT-1 freshen-up
Greg is good
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 11-19-2014, 12:17 PM   #9
John Nechiporchik
Thanks everyone. Looks like a call to Greg is on the agenda.
John
Old 11-19-2014, 05:02 PM   #10
John Nechiporchik
Spoke with Greg today. He is a wealth of knowledge. Looking forward to doing business with him.
John
