Old 10-06-2014, 12:18 PM   #1
SSGN
SSGN's Avatar
Liked 203 Times in 52 Posts
Lightbulb Daily Driver oil
What is everyone using for daily driver oil? I just purchased a new chev truck and it recommends dexos and I have always used a dino oil and changed often but most companies for this requirement are a full synthetic. All 3 of my DD's use 5w/30. Thanks in advance for the advice
Kevin
Old 10-06-2014, 01:11 PM   #2
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Re: Daily Driver oil
Dexos is a fancy label...here is the link for all of the oil/brands that are certified.
I use the recommended type in our daily drivers...
http://www.centerforqa.com/gm/licens...dexos-products
Old 10-06-2014, 01:17 PM   #3
SSDiv6
Kevin
Dexos is just a specification from GM. They have licensed many oil companies to put the Dexos label on the container after paying GM a hefty royalty.
I recommend and use Pennzoil Platinum Synthetic for all my vehicles; it happens to meet the Dexos requirements from GM.
Old 10-06-2014, 04:01 PM   #4
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Kevin, I ran my 2003 F250 6.0l to 425,000k on Royal Purple 15W40 and the current 2011 F250 6.2l has seen almost 70,000k running on RP 5w20 since I bought it at 125,000.
(....besides, we sell the stuff )
Dave Turner
SS/GT #1153
Old 10-06-2014, 05:22 PM   #5
Ed Wright
Ed Wright's Avatar
Hard to beat Mobile1.
Ed Wright 4156 SS/JA
Old 10-06-2014, 05:25 PM   #6
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
Mobile 1 here as well.
I have had two different motor builders say they like the way things look inside after Mobile 1 has been exclusively run.
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 10-06-2014, 05:51 PM   #7
Tom Moock
Liked 10 Times in 6 Posts
Kevin, you have 20,000 miles to pick a brand of oil, gm gives you 4 free oil changes when you buy a new truck. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 10-06-2014, 07:58 PM   #8
Tim H
Tim H's Avatar
Liked 485 Times in 160 Posts
Dave, I used to sell the stuff when I worked for NAPA and I recall the back of the bottle stating in fine print that it should not be used in 2005 or maybe 2008 and newer vehicles. Has that changed ? My daily driver vehicles all use Valvoline.
Old 10-06-2014, 09:02 PM   #9
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Daily Driver oil
I've seen the 2007 and newer recommendation on some Amsoil oils for diesel applications. I believe it was the extra zinc & phosphorous, that the older diesel oils had, that was removed for the newer diesels because it affected their newer style catalytic converters in a negative way. I don't know if any similar restrictions exist for newer gas engines.
LOCOMOTION Racing
Old 10-06-2014, 09:12 PM   #10
Dave Turner
Their new "SAE" line of oil addresses that issue Tim. They retained the Synerlec additive in the "HPS" offering for older applications....and charge slightly more for it.
Dave Turner
SS/GT #1153
