Old 03-10-2015, 06:49 PM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Rear motor plate
What is the minimum thickness a rear engine plate should be?
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 03-10-2015, 06:52 PM   #2
SSGT Mustang
Liked 204 Times in 54 Posts
Default Re: Rear motor plate
I use 0.090 steel and wouldn't go thinner....
SSGT Mustang is offline   Reply With Quote
Old 03-10-2015, 07:23 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
Duce,
The two common mid plates are 1/4" aluminum and .090 steel.
"Generally" you see the 1/4" plate in dragsters and tube frame cars. "Generally" you see the .090" steel plate in back half door cars.
I do not recall seeing any other options.
With my super 10 build I have 1/4" aluminum front, 090" steel middle.
Larry Woodfin 471W
Old 03-10-2015, 09:38 PM   #4
curtis reed
Liked 125 Times in 59 Posts
I do have 3/16" aluminum mid in my car with 1/4" front. Been running it for years. They are pretty narrow in my roadster though.
Curtis
curtis reed is offline   Reply With Quote
Old 03-10-2015, 10:56 PM   #5
FED 387
Liked 333 Times in 180 Posts
Just remember to tell your convertor guy how thick your mid plate is so that you have the correct mounting tabs for proper engagement!!!
Old 03-10-2015, 11:45 PM   #6
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Ed… .090 steel or .250 (T-6 6061) aluminum. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 03-11-2015, 09:07 AM   #7
SSDiv6
Liked 1,583 Times in 582 Posts
I am using an Aluminum mid plate on my Comp Super Modified car.
Don't see any issue on using an Aluminum Mid Plate on a back-half car if you don't go too thin in the material.
Old 03-13-2015, 08:04 AM   #8
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Don't forget to use a (for, aft) engine limiter.....
Old 03-13-2015, 08:14 PM   #9
Ed Carpenter
Yes that's what I thought. I'm getting movement. Mine is .250 aluminum in front and .090 steel midplate.
Ed Carpenter
