Liked 99 Times in 60 Posts
What are some engine mounted pumps that give excellent service and performance? Also, what return regulator?
Thank You
Larry Woodfin 471W |
Liked 1,912 Times in 429 Posts
Why? Not sure what you're trying to do, or why you want to reinvent the wheel.
Pumps do not like to "pull" a liquid, they much prefer to "push" it. The higher the demand, the great degree of difficulty and the higher the expense involved in make a pump that "pulls" work. Adding the G force of acceleration to that only makes things worse. There is a good reason 99% of all faster Stock and Super Stock cars run a rear mounted electric fuel pump such as a MagnaFuel or Aeromotive, at or behind the cell.
Alan Roehrich 212A G/S |
Liked 319 Times in 68 Posts
Why introduce engine heat to the fuel system?
Lee Valentine 1661 STK |
my question comes form years of bracket racing with a BLP belt drive pump and bypass regulator.
That sure works good, low fuel pressure at low speed, full pressure at race RPM. I thought some might be running an engine mounted pump, looks like not. Out of curiosity, do we know what NASCAR engines use for fuel pump? I have seen photos of those engines with block mounted pumps.
Liked 2 Times in 2 Posts
Looking around the web and found the Nascar boys used these, until fuel injection a couple years ago.
http://www.watermanracing.com/Produc...-w-bracket.jpg |
#6 | |
Liked 5 Times in 3 Posts
Liked 13 Times in 7 Posts
Stick with your BLP pump or go with an APD pump. A lot of weekly bracket racers still use the older edelbrock speedway pump and with alcohol. Rear cell is also not a problem for a 9-11 second car
N/A |
Mannymen,
belt drive pump not allowed in super stock. If it were allowed, that would be my choice.
Liked 778 Times in 142 Posts
Wheelstands make the problem of a front mounted pump even more difficult..
