Liked 165 Times in 51 Posts
Can you run a 57 chevy in stock now?
What class will it fit with what engine combos?
Glen DeMenge 1969 Camaro Stock Eliminator |
Liked 319 Times in 108 Posts
Yes you can run 57,not sure on combo's should be in guide,I know probaly 265,283,235 six
don't know what combo's of these engines but know they came with them Mike Taylor 3601 |
Liked 99 Times in 60 Posts
I understand it is not your original question, my thought, sure would make a good GT or Crate Motor project.
To answer your original question, to my knowledge a 57 is acceptable in stock with any of the original factory engine combinations. [as posted above] Also, how cool with it be to run the 283 with 2 carbs. [a 283 - 283 horse was available in 57 with four speed. it used a low profile 2 x 4 intake]
Larry Woodfin 471W |
Liked 7 Times in 7 Posts
Larry...the 283/283hp engine was with Rochester Fuel Injection and Duntov 097 cam....
There were 2-2x4 carb combos...270hp with the above mentioned 097 cam...and 245hp with a regular hydraulic cam...Cylinder heads and cc's may differ as well so one should check the latest NHRA engine specs to see what's permitted.... Was the 250hp FI engine (with regular hyd cam) available in '57 or did it come later? |
yep, my "old timers" is showing
![]() also, the correct carbs and manifold while could be found, whew, talk about expensive.
Liked 5,153 Times in 1,967 Posts
The 283 4bbl can use the 459 327/250 intake now, plus a 3 speed trans..Not a bad P/SA
car. The 283 / 245 2x4 deal would be more expensive to build. It would probably be somewhat faster , but I doubt it would cover the half second index loss.
