Greetings all
I am running a glide with a Hurst Pistol Grip Quarter Stick with the cable coming out the front of the shifter, I have clearance issues between the selector on the trans & the chassis rail of the car I am thinking to go to a rear exiting shifter & run the selector lever on the trans upwards instead of down were it presently is & this should give me the clearance I require any suggestions as to what stick to run, I need to be able to fit a CO2 shift solonide to it as well regards Rod |
Liked 1,914 Times in 429 Posts
QuarterStick II.
Alan Roehrich 212A G/S |
Liked 3,230 Times in 982 Posts
Have always loved Paul Forte's shifter. Turbo Action is one of the few manufacturers that pays contingency (see their website or call Paul for details). You can also get different gates for fwd/reverse pattern, 2 or 3 speed and can convert it between fwd/reverse cable entry without anything extra to buy (changing the air cylinder from front to back at the same time).
Sponsor
Liked 63 Times in 11 Posts
Check out our SHIFT product for your powerglide - no cables!
