Old 05-06-2014, 09:55 PM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Default fuel pressure gauge
Any tips, lessons learned from installing plumbing for fuel pressure gauge for 4gc on 66-67 chevy II. Regulator mounted on passenger side of car and fuel gauge mounted near cowl and driver's windshield wiper location. thanks
Ed
Ed McLawhorn Jr. is offline   Reply With Quote
Old 05-07-2014, 12:42 AM   #2
SS Engine Guy
Default Re: fuel pressure gauge
The larger the line diameter, the more instant the correct pressure reading. I would suggest braided line with correct fittings even with the extra room needed and extra cost. A correct pressure reading can sometimes help diagnose problems and also monitor fuel pump condition. Remember also that volume is really important also on a carb motor. A clear plastic gallon jug measured to be an exact gallon is always at my shop and in the trailer. My opinion, regardless of the et, is pump a gallon after the regulator, in 20 seconds.
If FI I would take pressure directly off the fuel rail or log. Just remember that you need decent sized line to give instantaneous pressure readings whether by guage or data logger.
SS Engine Guy is offline   Reply With Quote
Old 05-07-2014, 10:43 AM   #3
FED 387
Liked 329 Times in 177 Posts
also remember pressure and volume are not the same thing-- ya can have great pressure and very little volume and vice versa great volume and very little pressure ---ya need X pounds fuel pressure and X gallons of fuel volume for maximum performance--FED 387
Old 05-07-2014, 10:21 PM   #4
Ed McLawhorn Jr.
thanks guys. Will keep those recommendations in mind.
Ed
