Old 05-18-2014, 09:10 PM   #1
js72mav
Default oil pressure
Got a question about oil pressure. I noticed during my last run that when the car shifted into 2nd gear my oil pressure dropped to about 15-20 for approx. 1 second then went right back to 45- 50 for the remainder of the run and the return road. The motor is a super stock Ford 289. I use a canton pan and pick up. I double checked the pan to pick up clearance and seems to be ok. Any thoughts??????
js72mav is offline   Reply With Quote
Old 05-18-2014, 09:33 PM   #2
pmrphil
Liked 347 Times in 151 Posts
Default Re: oil pressure
Is it front sump or rear?
Also, HV pump or std. volume?
Phil Molski
PMR Performance
S/C 1623
Old 05-18-2014, 11:24 PM   #3
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Maybe the oil is shifting to the rear while the car is accelerating while the wheels are up ,and Wow you are really multitasking I can barely watch the fuel pressure gauge and its right in my face.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 05-19-2014, 12:08 AM   #4
Don Higgins
Mine does that when I get low on the oil level.
Don Higgins - Super Comp #360H
Don Higgins is offline   Reply With Quote
Old 05-19-2014, 06:27 AM   #5
js72mav
Sorry, it is a front sump pan and a standard volume pump.
Old 05-19-2014, 05:44 PM   #6
Mark Ugrich
Liked 71 Times in 38 Posts
Is the sump open around the pick-up? A trap door/ baffle would help keep the oil at the pick-up.
Old 05-19-2014, 07:23 PM   #7
Greg Hill
Liked 279 Times in 68 Posts
Add another quart of oil.
Greg Hill 4171 STK
