Old 04-28-2014, 03:07 PM   #1
njk53
Default Adjusting Valve Lash with Schubek/Smith Lifters
How are you guys out there that are using Schubek/Smith Machine limited travel lifters adjusting your rocker arms. We were told to adjust to zero lash which we do but, my question is are you giving the rocker an extra 1/4 turn, 1/2 turn etc after zero lash is achieved. Or when zero lash is achieved do you stop there with no extra turn?
Nelson Kowal
Stock 345
Old 04-28-2014, 03:42 PM   #2
Rsmith38
Liked 28 Times in 15 Posts
Default Re: Adjusting Valve Lash with Schubek/Smith Lifters
No extra turn - Sherman info says .001 clearance.
Rsmith38 is offline   Reply With Quote
Old 04-28-2014, 07:11 PM   #3
MR DERBY CITY
Liked 8,210 Times in 1,536 Posts
Regarding adjustment for shubeck hydraulic lifters in a small block Chevy, I was taught by the best , Woodro Josey. Zero lash and you want a small amount of drag on the pushrod. Please take your time and do this correctly or the outcome may be catastrophic. M.J.
Old 04-29-2014, 12:53 PM   #4
GTX JOHN
Liked 2,493 Times in 700 Posts
I adjust Zero lash and make sure that I can only turn the pushrods with quite a fair
amount of drag
Some of them have 015 travel and some have 030.....Terrible quality control.
If they get loose the puck sometimes fall out and destroys the engine!
Check lash often a look for any bending pushrods increasing lash before
disaster strikes!
Your results of course may vary.
John Irving
741 Stock
741 Super Stock
Old 04-30-2014, 10:43 AM   #5
njk53
Thanks to all who replied
Nelson Kowal
Stock 345
