Liked 302 Times in 73 Posts
What's the rule? I know it has to go in same direction as factory but does it matter if it a factory piece.. specifically throttle body..Same size holes is all that matters or do I have to have the part number specific throttle body?
Brad |
Brad, You wouldn't need a specific part number...Just a Ford part with the correct venturi size...unless there is an accepted aftermarket part i.e. Edelbrock for a Qjet or Quick Fuel for a Holley.
So on the 2010 352 CJ combo. Accufab actually made the 4 hole throttle body.. Ford racing doesn't sell the throttle body anymore and Accufab does, but it has Accufab all over it instead of Ford Racing.. It's also about $70 cheaper than I can find one on ebay that has the Ford markings and I also have a Ron's Racing fuel injection unit that is obviously not the right piece but it has 4 holes and they are the correct size.. would I have to get either of those approved by NHRA because they aren't the actually Ford pieces??
Brad |
Liked 7 Times in 5 Posts
how much is the cheapest one you have found?
#5 | |
Liked 279 Times in 68 Posts
Greg Hill 4171 STK |
Rawhide... I must have looked at it wrong I swear when I searched your add the TB was listed at $590 not $550.. I'm sure I'll be in touch soon. I'll know if I am doing this motor in the next month or so
Brad |
