Posting for my dad:
SOLD Engine 496 Chevy Big Block Chevy block, Cola crank, Manley Rods, J&E 13:1 pistons, Dart heads, Dart intake, Comp Cams 714/714 cam, roller rockers, and lifters. Stud girdle, Quick Fuel 1050 carb, MSD crank trigger, MSD distributer, Jessel belt drive. Engine rebuilt in 2012 Transmission Rebuilt fall of 2013 Pro brake, stock case PowerGlide 180 Transmission Specialties straight cut gear set ATI Converter, 5500 stall Suspension' 9" Ford rear end with 4.30 pro gears Ladder bars Tubular front control arms QA1 shocks Coilovers in rear Willwood disk brakes with stainless brake lines front and rear Other Mega 450 delay box MSD 6AL RPM switch, 2 step Quarter Pro air shifter Flaming River stainless steel tilt steering column Weld Racing Pro Stars, 31x14x15 Hoosier slicks, Mickey Thompsons on front K&N air cleaner New belts Optima Red top battery 5 gallon fuel cell with Holley Black pump Chassis certified in July of 2014 to 8.50 Mild steel cage, stock steel firewall and floor up to the tubs. No motor plate, steel motor mounts. Stock cross member that's been notched for oil pan clearance. 2 padded seats Title in hand $7500 in paint All lights work. Can be streetable. All steel except for hood All glass Front windows roll up and down Car built and finished fall of 2011 Would make a very good Super Street car Send a PM with email address for more pics $23,000 obo This video is the 2nd time it was down the track after being built. ![]()
JJ Nance '06 Don Davis C5 Corvette Last edited by S/G 386N; 10-28-2014 at 10:56 PM. Reason: sold |
