Liked 43 Times in 29 Posts
Just came across a case of this BG 20-50 racing oil and was wondering if anyone has any recommendations for it. Either it's ok to use or stay far away from it. The application for use would be a 275/327.
Mark Ruset 2048 STK |
Liked 1,914 Times in 429 Posts
Mark,
I'd be just about stunned if your little 327 needed or wanted anything close to 20W50, I don't even run that stuff in the 750HP 396 Super Stock engine. The thickest oil you should ever need or want is probably 10W30. That thing would probably be real happy with 0W20, or 5W30, unless it is a lot looser than I think it is. Thick oil just slows you down, and wears the distributor gear (on the distributor and the cam) among other things. If it makes you feel better, I'd say 10W40 in the summer down there in the heat, in bracket mode would be okay. If you're running 20W50 now, you'll probably find a fair amount of ET in 0W20 or 5W30.
Alan Roehrich 212A G/S |
Liked 319 Times in 68 Posts
Just run glue, it's cheaper and probably faster.
Lee Valentine 1661 STK |
Liked 240 Times in 112 Posts
If you use that oil, use a heater with it as well. A 50 weight @ 212 degree's is thinner that a 0 weight @ 75 degree's.
Dave Noll, EF/S ,?/SA 6526 |
#5 | |
James Schaechter 3163 STK |
#6 | |
Larry Anderson 71 Dart Swinger 416 Storker (Augie). http://i58.photobucket.com/albums/g2...11/Dart416.jpg |
Larry, I'm not a Mopar guy but they are all engine's. Alan's advice is sound. I said what I did because a 20-50 was a popular oil for the roundy guy's but those motor's spend some time getting warm & buy the time the race is hot & heavy, the oil is @ 20 centistokes. Not so much in our drag racing. (unless it's a street/strip car driven to the track) I spent some time reading here:
www.bobistheoilguy.com Then I put a wide sweep oil pressure gage in my daily driver (95 escort w/195,000 miles) & started playing with grade's. I know my racecar has different needs, but it's interesting.
Thanks Alan and to all that replied, I've never used anything else but Valvoline 10/30. I'll keep the BG far away from the Camaro.
thanks... I like lucas oil that's what I run in my old dart and what I was going to run in the new car and engine...the reason I use lucas is because I had some work done on the last motor an when the guy I had doing the work ask what kind of oil I was using I said lucas he said that the bearing had little or no wear in them . but I do use Valvoline in my truck and my wife car big fan of it. what about the VR1 from Valvoline??? I have heard that some like it for a race oil and a good break in oil. I don't know how true that is.
Liked 138 Times in 51 Posts
As outlined, while the BG 20w-50 is a higher viscosity than needed for drag racing, especially for Stock, it may at least have higher levels of zinc & phosphorous most people recommend for older performance & race applications, as well as break-in. But you have to do some research to know which oils still have higher levels. "Shelf" oils for newer cars and diesels have had a lot removed and even some racing oils don't emphasize the ppm content.
It's explained a bit more in this Amsoil bulletin: http://www.amsoil.com/techservicesbu...t%20Tappet.pdf Of course, if you have Schubeck/Smith lifters, it isn't as critical.
LOCOMOTION Racing |
